gjsentilles
Thread starter- Joined
- Sep 3, 2002
- 3
1995 70hp Johnson idles briefly (10-20 secs) then quits. Can keep it running with the primer if I catch it quick enough, but eventually (5-10 secs) dies. Should say when it is running it doesn't seem to be running on all cylinders. Can then wait a few minutes and repeat over and over and over... I have checked the fuel pump by disconnecting and cranking, seems to be good flow. I removed the number 1 carb and it was immaculate. I haven't checked the other two as I am doing this on the water and is very difficult. Timing light shows spark on all plugs. Timing at idle (when it runs long enough to check) is -4. compression test looked good although my tester isn't the best. I changed to another fuel tank and different fuel. Did notice a slight differnce (ran a little longer) at first but then returned to the pattern described above.<br /><br />For what its worth, when I first started chasing this problem, after being stranded on the water, I had and inconsistent spark. I eventually traced this to a flaky connection from the powerpak to the sensor screwed into the top cylinder head. After fixing this it began to start more consistently but the idle problem remains.<br /><br />Also the VRO has been removed and plugged on this engine by a previous owner. Other than that the engine is very clean and shows little wear.<br /><br />Thanks for any help.
