Exhaust connection was secure, I pulled the plugs and blew out the cylinders, did not see any water. Still missing terribly. Possible spark plug wire? I am not sure how to open the electrical box, There is a screw out plug that shows the main fuse when you pull it out but I do not see how to get the box cover off. Should I be checking compression at this point??
Thanks,
Thanks,
