Runs about half to two thirds full throttle then gets worse. Will barely go with throttle wide open. When you open the cover has alot of smoke. Tested both cynlinders and fire and compression are fine. Changed spark plugs and fuel filter very little change. The smoke bothers me and the water coming out the side, not the back is hot.
Any suggestions before I spend money on a real mechanic?
