Fishin with buds
- Apr 13, 2007
- 31
Greetings,
So i picked up this engine, had an inspection done by a Yamaha Master Mechanic, and it checked out. Cool, right...?
So got it hung on the boat, first spin and i noticed that it fluctuated RPM's in the mid to upper range. Like 3000 rpm+ i would have a 200rpm fluctuation, maybe a 3 second interval...but not all the time, sometimes it works for 20 minutes, then goes into this symptom for a while. This i can live with, but dont enjoy.
Second issue is that sometimes it will die at idle, after running for a few hours. Then, restarting is not an option for at least an hour. if i take it home, it will start first crank on the hose, but not right after it dies on the ocean. changed the fuel water seperator and got the same result, towed back again.
Oh, so heres what i did...i premixed some oil in my tank, just to make sure that my oil injection system was all working properly before i learned it wasnt the hard way. so there is about a 30:1 in the gas. second, oil tank is not hooked up. i add oil to the axuillary tank when needed. also, fuel line is old and has an old seperator and valve on it.
so the first time i took it in, the mechanic took me a week to tell me i needed to fix all "this sh*t" before he could help me, mainly dilute the oil in the gas, replace the fuel line to the tank and hook up the oil tank. fair enough. did the first two, have not hooked up the oil tank yet as, well i just havenet and i figure its only purpose is to keep me from pulling my cowling off and adding more myself, so i dont see it as making or breaking the situation. but maybe ignorance is bliss....
so my buddy had it down at the ramp, started right up, shut it down at the dock and it would not restart.
so, before i take it back to the mechanic who has yet to impress me or be helpful, i just wanted to give a cry for help and see if anyone had any ideas.
thanks and merry christmas!
