94 Yam 150 - Timing plate set screw location
esteym
I've looked through my manual and I cant find the timing plate set screw, no posts on it either.
also need the location of the upper and lower adjustment timing screws.
Also, any suggestions where to find a Dial indicator and if I need it.
thanks!
mike
Ray Neudecker
Re: 94 Yam 150 - Timing plate set screw location
Look where the upper control arm stops at idle and wide open throttle and you will see the stop screws.
esteym
Is that the timing plate screw location or the upper and lower? I think it is the upper and lower, do you know where the timing plate screw is?
Thanks
Mike
Ray Neudecker
Not aware of a timing plate screw. Are you asking about the indicator screw?
esteym
I was going through the manuals description of things. Usually they are very good about giving you a picture of the location. It is in the first part of the timing process where you use the Dial Indicator to find TDC and adjust the plate to hit tdc on the flywheel I think (I dont have the manual with me now). If it is the arrow thingy then I just answered my own question if not then im clueless.
Thanks
Ray Neudecker
That is to align the indicator, the arrow thingy.
esteym
thanks - one step closer...
