94 Waverunner 700 Carbs?
EBlake
As I stated in another post, I just bought a really clean 94 Waverunner III, but coming from an ATV, Dirt-bike back-gound I have a few carb questions.
I purchased the shop manual, but it won't be here before we leave on a long weekend trip to a big lake.
1. On the front of the carb(front of the ski direction) is a small brass wingnut looking device that is easily turned in & out. I've done a lot of carb adjustments on rec vehicles, but have never seen this. What is it?
2. The ski seems to be running a little rich at low "no-wake" speeds. But until my book gets here, is there somewhere I can find out if &/or how to adjust it before our trip?
I'm planning on re-build the carbs over next winter, but over all the ski runs really well & will be fine for the rest of the season, just wanted to "tune" it if possible.
Thanks.
B
The Penguin
Re: 94 Waverunner 700 Carbs?
sounds like your "wingnut" is either the top or bottom end adjuster screw. I forget which one faces the front of the ski.
best bet on the stock screw setting is a manual - you should be able to find a link online for that ski to set it.
