94 suzuki dt 40 running poorly with miss
Billten
I have a 1994 suzuki dt 40 that I have rebuilt the carbs on that now runs better than it did. I broke down twice when I wasn't out that long and it just died. I couldn't start it back up. Fuel pump is good and new gas in clean tank with Seafoam and Startron in it. When running with the muffs it starts fine but runs rough and has a miss that can almost be a backfire. The water pump is new and is pumping and it seems to be pumping oil. Any help out there?
stylesabu
Master Chief Petty Officer
Re: 94 suzuki dt 40 running poorly with miss
did you put new spark plugs in it? sounds like its running lean
Billten
First thing I did was put new plugs. They are fouled dark and seem wet though. I will clean them and retry for starters. Also, did not check strength of spark or do compression test yet.
