'94 Mercury 40hp making knocking noise....please help!
Gigemaggie
Hey guys need some help! Just bought a 17ft duck boat with a 1994 Mercury 40hp tiller. When I test drove it ran perfect no issues. A buddy and myself installed a hydraulic jack plate to the boat last week and took the boat out later that day. As soon as we started idling away from the ramp the motor was making a lknocking noise, almost like we were hitting a log or something. We figured out the motor must have been trying to shift back into neutral because if i put a little pressure on the shift lever it would solve the knocking noise and run awesome. I didn't have to constantly hold pressure but would at first when shifting into forward. Was hoping this is not a clutch dog issue, hoping its just the lever and/linkage but could not figure out how to adjust. It did not make this noise in neutral or reverse. There is quite a bit of play in the lever.....any ideas?
hemi rt
When you put the jack plate on you may have changed the shifter cable length. Check that it is adjusted properly.
Gigemaggie
Thanks! I am assuming I need to tighten cable. Seems like the only way to get to it is by removing the throttle body. How do I tighten once I can access? Sorry not very mechanically inclined!
Gigemaggie
I think I got her figured out. Found the spot near lower unit to adjust cable. Tightened it up a bit....hopefully this solves it
