94 mercury 115 on astroboat oil light/buzzer going off please..need help!!!
astroman01
Hey everyone I already put a post out yesterday, I have had a total of 8 views but no replies. Please I need help!! Heres my problem again my motor was running fine when it was running until I came in to beach it on the shore, I shut off the motor but did'nt realize I left it in the on position. I came back from eating luch about hour later and the low oil light was flashing and the overheat buzzer was going off. I don't know how to shut it off the motor can set for a week then as soon as I turn the key to the on position its still doing it. Please someone help
delsol
Re: 94 mercury 115 on astroboat oil light/buzzer going off please..need help!!!
did you suck sand in the motor, check your water pump..they say steady sound buzzer is overheating or temp sensor..could be other things but check the easy ones first
Drybo
1. run 50 -1 premix till you solve problem
2. My 115 needed a new float in oil tank(take oil tank off turn upside down, if beep stops it is float.replace tank or find somebody that can fix the current tank.
3.The module may be bad.
4. The oil pump may have failed.
wilde1j
And you can add, the plastic gear driving the oil pump driven shaft may be or have failed. The oil pump itself rarely fails.
