'94 Kawasaki 750ss overheating?
phillieswon
The very back of the rear cylinder is running noticeably hotter than the front cylinder. There is some discoloration in the area. Could this be due to a clog in the water jacket in this area? The ski however has been running great for now. If i take the cover off to inspect, can i reuse the same gasket and if there is stuff in there how should it be cleaned out? There is good flow from the pisser and the water coming out is not screaming hot.
Thank you,
Eric
