Hey all! New to the forum as of today!
Sorry in advance for the lengthy post, trying to include as much info as possible!
I'm was hoping I could get some help with my overheating issues on my 94 Johnson 140 V4.. It's sitting on a 19 foot center console. I just bought this boat one month ago, and the previous owner showed a receipt from a boat mechaninc in Riverview FL. The receipt lists;
(5/11/2011)
2 143 deg. T stats
2 diaphragm cup
1 water pump kit
2 gasket t stats
4 spark plugs
4 carb kits
1 trim motor
1 stator 9 amp
2 shift shaft o rings
1 hose gasket for 55 housing?
Also previous owner removed oil injection tank, so I just premix with Johnson 2 stroke oil, 50:1
I also just did a compression check my self and found 135 psi on 3 cylinders, while port side top was at 130 psi.
Also had 2 fuel hoses that were loose, tightened up, starts immediately, runs great! Smooth, quiet, shifts nicely.
Now for the problem... When running at higher speeds, I usually like to cruise at anywhere from 4-5000 rpms.
I run in salt and freshwater.
When running at higher speeds, after 10-15 min the high temp alarm comes on, as well as the slow feature. I'll back the throttle off, anchor, sit for 5-10 min and it re sets. The alarm will not come on at slower speeds or idle. I have noticed though when at idle the pee hole stream is fairly hot. This afternoon I will attempt to back flush.
The intakes are clean, I will look inside the impeller housing to make sure there's nothing inside of there as well.
Any other suggestions/comments would be greatly appreciated!
Thanks
(5/11/2011)
2 143 deg. T stats
2 diaphragm cup
1 water pump kit
2 gasket t stats
4 spark plugs
4 carb kits
1 trim motor
1 stator 9 amp
Thanks
