94 chev 4.3 mercruiser
me235
I a 94 Blue water Mirage with a chev 4.3 vortec with a mercruiser outdrive. I am re-ringing and bearing it. i was wondering if there is anything special about the gasket kit i will need for the 4.3 or if a standard fel-pro gasket kit will work? also, anything special about bearings and rings? or will standard automotive ones work as well??
Thanks for your time!
Re: 94 chev 4.3 mercruiser
Ayuh,... Fel-pro is Good Stuff,... No problem... Quality parts, are Quality parts...
me235
Ok cool thanks! I just wasn't sure if since it was marine if it needed something special for gaskets or anything.. What about bearings and rings? All the same?
