94-96 mercury fuel problem
admiral1951
well here i go again, this 115 merc will not stay running. it have clean carbs,new fuel pump,new fuel lines,new tank and bulb,clean accelerator, clean gas and oil, but why it wont stay running for a few minutes. it will stay longer if i hit the choke easy, do you have any answer's out there.:mad:
bktheking
Re: 94-96 mercury fuel problem
Wrong forum, if it stays running if you are playing with the choke then the carb's aren't doing there job, I suggest doing another clean. Is there an idle adjustment on the carbs?
admiral1951
did clean carbs twice,will run for a minute then stop all of a sudden.there is two idle adjustments on the top two carbs. there are four fuel adjustsments compression is 120 across the four cyls
