94 88hp Johnson Tach/Charging System Problem
Ruston11
i have replaced stator and rectifier and still have no charging. There doesn’t appear to be any A/C volts being generated by stator. Voltage is 12.8 running My original stator homed out at 121 and the new one is 60. Is it possible to have bad flywheel?
Joe Reeves
Error... Transposed comment that belonged elsewhere.
Fed
The stator resistance for the 12 V (the 2 yellow wires) should be much lower than that, 0.7 Ohms for a 9 Amp stator and NO shorts to ground while disconnected.
