What is the best way to adjust the valves on a 305 5.0. I have been told to adjust with #1 at TDC Exhaust 1-3-4-8 and intake 1-2-5-7, then roll the engine 360 and adjust the rest, turning each nut one full turn after the lash is removed. However, the machine shop that installed the valves says,
adjust both #1 valves at TDC, then roll the engine 90 degrees and adjust each cylinder according to the firing order continuing to roll the engine 90 degrees after each pair. Also he recommends turning the adjusting nut about 1 and 1/8 turns after removing the lash.
