Re: 94 3.0L EST ignition
Well......figured it out.
1. There was a hole in the Sierra manifold that must be plugged that causes a serious vacuum leak. Makes the thing run on 3 cyls. (the hole was about even with #3) the other cyls seemed to run ok. pulling each plug wire (one at a time) made it run on 2 cyls (except when I pulled #3) putting a bolt in the hole sealed up the vacuum leak and it ran well on all 4.
2. Once I got it running good enough to get it below about 1200 rpm I could see the module change the timing.
3. The interrupt switch actually applies 12v to the module to activate the interrupt.
(so bypassing the switch is like activating it)
4. connecting the 2 white wires will then allow the engine to run (once the interrupt is activated by bypassing the switch)
5. If you have a big vacuum leak it's very hard to set the timing (or anything else for that matter!!)
Whew!
Thanks Don, for reminding me about the shift interrupt switch. I think the first time I tried it I didn't actually bypass the switch which is why the engine dies when you pull the white-wire jumper.
I think I am finally starting to learn something about this stuff!! I'll actually be able to find a job doing it when my wonderful union brothers decide to strike......I may still be able to make the house payment!!
