I have a 94 Mercury 25 hp outboard remote steering that the reverse gear and clutch went out on. I have installed the parts, new oil in lower unit and stainless steel prop. I still do not have reverse. Can any one help? Is there a special trick to re-installing the Propeller shaft and hub when replacing the gears and clutch?
