My 120 Evinrude has no spark on all four cylinders. I have done the ignition system check called out in the Seloc manual for this problem, which tells me to check the stop circuit (OK) then check charge coil. The coil had a lower output voltage than called out in the book and the resistance was lower than called. I changed the stator, like the book tells me to do and I still have no spark. Now I need help. What should I look at next?
