scottfromoz
- Jan 1, 2006
- 90
Hi all. My 93 performed really nicely today, but alas after tilting up for trailering going home she would not tilt back down onto the bracket stop...tried going back up, nothing. Noticed a little weeping oil from the seal at the top of the tilt tube. I tried using the manual bleed screw in the side of the tilt bracket but even with that open it will not drop back down even with force....I have looked in the manual and it has not troubleshooting for this problem...any ideas greatly appreciated.
I have not checked the fluid level yet (too late tonight for me!) but it seems odd that even if the fluid is low it will not fall down/be pushed down by me when the bleed screw it turned fully...
Also, what is the best method of servicing the seals in the trim and tilt hydraulics...or is it more cost effective to replace the trim and tilt units with a good second hand or new one...
Cheers
Cheers
