at the lake this last weekend the Seadoo was running really hot. I'm sure it is getting good water flow but it doesn't seem to be pulling oil from the oil tank. It seems like the oil pump is going bad. I took it over to my tech last night and he pulled the head and said it looks really good. No water flow restrictions. He recommended just pre-mixing the oil in to the gas which from what I have read here is a good idea. He said he is going to pre-mix some oil and gas and run the ski today to see if it still gets hot. If not, that would increase the probability of the oil pump going out. He says in order to run without the oil tank he has to order a oil pump bypass kit and basically disassemble down to the oil pump in order to install the kit. Pretty much the same cost to either install the bypass or install a new oil pump since he has to tear it down that far anyway. Does this make sense? Thanks for the help!
