93 OMC V115SLETS outboard fuel pressure
vincep
Having little trouble with my motor staying strong when i try to get on a plain. Wondering what the fuel pressure should be so i can check to make sure pump is working properly. I've already replaced pump, but the one that came was effective as it didn't work when i blew into it.
P.S., know where i can buy a manual for this? Someone got a part number for the manual?
Also, how can i tell if looper or crossover?
Double check that model #----Or post pictures of your motor.----I think 1995 was the first year for the 115 looper.----But there is something about your 115 HP model # that does not seem correct.
vincep
Here is a picture directly from the motor.
Ok ----some pictures of cowling and the cylinder heads ?----It is a 93 model so it would be a CROSSFLOW.-----The first thing in trouble shooting is a compression test.-----These crossflows are world famous for breaking the piston rings.-----Seen many , many failures myself.------That leads me to say that every one of this style engine will suffer from that sickness !!!
Just found the model on the " quiet rider " list 1993 model cross flow.---Do that compression test.
