93 ocean pro 200 problems Help!
Vitamin Sea
well here's what I have 'Whenever I start the motor for first time for instance going out it starts fine but missis for while as if it was extemeley cold natured and it will spit & sputter and miss for a period of time until i get down on it or (push in choke helps) after which it seems to run fine and ocasionally it sound like its not running on all 6 and all of a sudden it will kick in and run fine the rest of the day I was wonderin what things should i be looking for to help locate this problem . if any more info is needed let me know
johndezman
Re: 93 ocean pro 200 problems Help!
had a similar problem earlier this season. mine turned out to be the low speed adjustment on the carbs was all over the map. my spec calls for 1 1/2 to 2 turns out from seated. i found anywhere from 1 turn to 3 turns. evened them all out at 2 and it starts and runs better.
vinney
CHECK THE COMPRESSION FIRST. ITS SOUNDS LIKE THE CARBS NEED TO BE CLEANED. THE CD BOX ON THAT ENGINE HAS A LIFE CYCLE OF ABOUT 8 SEASONS I FIND THAT CD BOX TO MAKE THE ENGINE HARD TO START AND AS TIME GOES ON THE BOX WILL DOUBLE FIRE AND CAUSE THE ENGINE TO IDLE POORLY. YOU CAN LOOK AT THE FIRE WITH A SPARK TESTER FOR 6 CYLINDERS. IF THE CARBS HAVENT BEEN CLEANED IN A COUPLE YEARS AND THE COMPRESSION GOOD START THERE. CLEAN THEM WITH ENGINE TUNER MADE BY VALVE TECH. THAT ENGINE HAS TO HAVE THE CARBS SYN. AND CHECK THE LINKAGE TO IDLE CORRECTLY. VINNEY
Dhadley
It sounds like it may have a problem in the Quick Start mode. <br /><br />Are you advancing the throttle for cold starts or letting the motor rev up by itself?<br /><br />Are the thermostats in?
