93 mariner, 135, head bolt lbs?
jhardesty
I need to know the head bolt torques....and is it right for the ground cable to spark when removed from the battery when nothing is on? And I installed an old battery to my starting system I have two batteries,,,,But my voltage reg burned out ,,after installing the old battery....it charged fine on a battery charger....could the battery have caused this to burn out ,,,or just bad luck ..it was going anyway....Thankyou..... wondering:confused:
sschefer
Re: 93 mariner, 135, head bolt lbs?
1. Head bolt torque is 30 ft lbs plus 90 degrees. Torque it to 30 then go another 1/4 turn. It works out to about 34lbs.
2. Spark at battery. If it's an EFI motor there might be a small spark otherwise no, not unless you have an always on accessory like a stereo that needs constant power for it's memory. Of course if you have it hooked up backwards it will spark and probably blow your rectifier/regulator.
3. Batteries won't blow a regulator/rectifier unless you hook them up backwards. A bad regulator will usually burn out to an open state. Was your battery not charging before?
4. Bad luck... Always been a believer that you make your own luck or mistakes as the case may be... It's lucky when you learn from your mistakes.
jhardesty
Thanks for the torque..settings...........and no I have not wired anything backwards... It was just odd that I just put this battery in ,,and the voltage reg. went out. And I will have to volt meter my wires to see what is pulling some current, it is not fuel injected, and no radio......I will check.....Thank you
