Hello Everyone.
I currently am debugging a short somewhere in my tilt/trim which causes the main fuse to blow when connected.
However, when the tilt/trim is disconnected at the motor, I am able to fire the starter without blowing the fuse (fuse remains cold, no heat) and the engine cranks. The problem is she just wont quite turn over (or if she does, she wont stay running)
It is almost as if she isnt getting fuel.
I was able to get her started by cleaning the carbs, and then spraying some starter fluid in there, but she only ran for a second and then puttered out. I assume this means that I have spark as she ran for a couple of seconds (she sounds like a good engine if I can just get her running)
My next test will be to premix oil/gas, disconnect the fuel line from the tank and run the mix straight in. Is this a good next step?
Additional information. When I remove the carb cover there is a little red knob that I can turn. When I rotate counter clockwise and push the prime bulb, gas flows out each of the 6 cyls. I am hoping this means I have good gas flow. Any tips on what that red adjustment does, and what I should have it set to (closed, wide open, somewhere in between)
Any tips on debugging this type of problem would be greatly appreciated.
Quick History: this boat has been idle for many years. I just bought it from the family of the original owner who died recently (natrually they told me the boat was fine when he died.. why is it all boat sellers are liers?)
Roy
Roy
