93 gtx just died?
mphy98
I was sitting at idle over the forth and it just died. No juice at all. Starter would not turn over no nothing. Where should I look? Is there a fuse somewhere that could have blown? Thanks in advance Bob
mphy98
Well put new battery and still no juice anywhere. anyone have any ideas?
sixfigures
yea that probably needs a new ground wire or both a new power cord and ground wire, try using a jumper cable from the battery negative to the engine and see if it helps get more power if so replace the main cables to the battery.
Blueghost924
If you replace the red and black battery cable and it still does not turn over, it's probably a problem with the MPEM.
