93 Glastron SSV 175 Stiff Steering
Got Wake 23
I'm new to this, so be nice...
I have a 93' Glastron with a Volvo 3.0l. My steering became very stiff at the end of the year, I just have the cable system, did not see any power steering pump unless I'm overloking it. Is there a way to determine if its the cable or not. Looking at other posts, it could be the cable, something on the drive connection or the box under the steering wheel. Only greese fitting i saw was on top of the drive. Any advice you could share to eliminate a few things would be much apperciated. Thanks. If you need more info let me know.
Re: 93 Glastron SSV 175 Stiff Steering
Ayuh,.... Welcome Aboard,...
I'm bettin' yer problem is just like the issue in Here...
Don S
Must be a really late model 93, since Volvo didn't start using the 3.0L until 94. What outdrive do you have? If you aren't sure, pictures work great.
Got Wake 23
I have pictures but it wont let me upload them to the site. saying its to large. trying to shrink these. under the dash there is a Teleflex Rack System. Drive is a SP COTRIM by Volvo. i dont know where to start to figure out if its this rack system bad, the cable, or the something in the rear.
Got Wake 23
figured out my issue...i disconnected the steering cable from the drive, drive moves super easy, disconnected up front at the rack system, steering wheel moves freely. its my cable. it wasnt easy to get out, little nervous on how I'm going to get a new one in. yikes. thanks for the help.
