Re: 93 force 70 HP low current/voltage from regulator
Check the stator AC output with the AC setting on your meter. At idle, you should get @14-15 volts at 2000 rpm you should get 18-20 volts. Also check the DC output at the regulator using the DC setting on your meter. At idle, it should be 12.5-13 and at 2000rpm it should be 14.5.
The readings are approximate but will let you know where your problem is.
John
