Hello let me first apologize for this being so long but I know as much knowledge as possible helps troubleshoot so let me just say thank you for your patience.
As you can see I am new to this website but I have been on here a lot reading previous posts and have got a lot of knowledge and information from here.
However I have run into a problem which is out of my hand and I don't want to take a chance of messing up something or messing something up more than I have. So I decided to reach out on here in hopes of getting some good instructions/troubleshooting help. Ok to start off I recently got a older 15' Cobia Bowrider boat with a 1993 50hp Mercury Force. I got a great deal on it. I traded some stuff valuing around $600 for the whole setup.
The motor was not running and previously sat for about 5-8 months. To get the motor to run all I needed was to change the battery(Lucky I know) lol..... and the motor ran good in forward/ reverse/ neutral... But the boat has been used in salt water and sat for awhile so I figured it needed some basic maintenance done to it to insure quality and long lasting function. Main focus being the impeller and gear lube. I will use the diagram provided by Boats. Net for parts replacement ( link at bottom) to explain some parts and things I touched/moved. Anyways, I bought a new Impeller, gear lube and begin the procedure to replace them.
Now let me just say I came into this a beginner/novice in the boat world but just did a lot of research to help me complete and I felt relatively comfortable with the job until now :facepalm: lol. I started by removing the nut that holds together the gear shift linkage. Then I removed the bolts holding the lower unit up to the midsection and gently removed the lower unit from the motor. Now to remove the waterpump housing and impeller I removed the Driveshaft assembly pole(#55 in link) from the gear unit by pulling up(took it out of the gear unit) then replaced and cleaned up everything nice and impeller didn't even need replaced but went ahead and switched it.
While that was out I figured I could go ahead and swap the gear lube. I drained it all out nice and put new lube in to it through the hole the driveshaft pole was in
with the vent screw out and made sure I followed spec for amount to use and everything went good. Now during this process the gear shift rod got knocked back and forth a little unscrewing it. If you look at the diagram look at #44 and #50 I think these connect. If so I believe it was the #50 pole that came unscrewed. Now I just made sure it looked right and screwed it all the way back down. Pushing up and down on it seems to be fine(as if it was shifting from forward to reverse).
Now got everything back together regarding the waterpump/impeller/driveshaft rod and stuff(so I think) and got it ready to connect back to motor. Now one thing I did not know and read before it was to late is to put it in forward before removing the lower unit. Anyways, took me like 5-10 minutes to realign/ajust and get the lower unit to connect to the motor again. Screwed all the bolts into place and reconnected the gear shift linkage(which was a pain). Now everything was back together and seems to be good to go. I started the motor and everything seemed fine. In neutral motor sounds great. I put it in forward and boom sounded like crap.
It shifted into forward but sounds horrible like a mix between a rod knocking and metal clunking and it seems to vibrate harder than it should. I turned it off checked around everything and started it again I put it in reverse and seems to be fine and sounds fine. Put it back in to neutral then into forward and this time it didn't go into gear. It stayed in neutral. So I pushed the throttle up more and about 3/4 the way up it kicked into forward but still sounded like crap. I put it in neutral and shut it off I jumped off and went to spin the prop in neutral and it spins fine like it should no resistance. I then put it into forward and tried the same thing and it still spun with no resistance as if it was still in neutral so then pushed the throttle all the way up and then tried to turn the prop and it felt like it should in gear and was tough(er) to spin.
So then I decided I needed to get some outside help before I end up turning this into a parts motor lol. I think I just messed up the gear linkage or maybe miss aligned it or something but how do I go about correcting it? As much help/info is appreciated.
Thanks for reading all of this and please be patient with me as I still am a novice/beginner in the boating world and don't know many parts/ names/ terms of boat motors and lower units. So when you respond please try to explain what stuff is the best you can. And if possible use part# in the diagram from the link I include.
Heres Link to Diagram http://www.boats. net/parts/search/Merc/Force/1993/H050412NF/GEAR%20HOUSING/parts.html
Take out the space obviously
lol.
Thank you all for your help.
