Engine will run and start with the throttle pushed all the way forward in neutral, but when throttle is pulled back to idle to put in gear, engine stalls. <br /><br />Engine ran perfectly normal 1 week prior.
Re: 93 Force 120hp will run only at full throttle in neutral
Welcome to the Iboats Forum. <br /><br />You could have any number of fuel system problems. But if you can only start at full throttle (not good for the motor) -- you could be dealing with flooded carbs. So the first thing you may want to check out would be the choke system's operation.
