93 Force 120 hp trim problem
ddzurik
Hi all,
Kinda stupid question about my trim but......this is the way I bought it.
93 Maxum 18' bowrider. When the motor is tilted/trimmed up the center cylinder
should extend and when it is out all the way the tilt cylinder should tilt the motor up
and out of the water. Mine actually tilts up but the center cylinder is in. When I trim it down
the motor comes down and the center cylinder tries to pop out. I think somebody put the stainless
lines in the wrong ports on the manifold. My system has the valve block between the pump and the
mounting bracket with all the 4 lines pointing down. Does anyone know which line goes to what port.
My manual does not show that.
Thanks
Dave
RRitt
Re: 93 Force 120 hp trim problem
undo all four ports. install plugs in three of them. run pump and see which direction fluid squirts out => up or down? mark port and move on to next one.
