this is a 93 5.7 with bravo 2 set up, the u joints and gimbal bearing and oil were repalced and there is a niose in the upper case, not sure if it was there prior to replacing u joiunts but it sounds like marbles bouncing around, the sound picks up with engine speed, in reading other posts i found mention of clutch cone bouncing around and it being common, i do not believe this is the case, the noise is very prominent over the sound of the exhaust, although not heard in the boat . this is all with the boat out of the water, run on muffs. the noise kind of sounds like an alpha 1 with an improperly adjusted shift cable where the prop is partially engaged. but yet the prop on this bravo spins freely(neutral) with the boat running and the noise is definetly in the top . any help is greatly appreciated
ok, a little update, i found that when the drive is turned to the right , the noise deminishes a bit.
