j_k_bisson
- Oct 6, 2010
- 1,082
Watched a couple of U-tube videos on how to by-pass the oil injection system on my 1993 75 hp Marine. All they do is disconnect they wires from the oil sender in the oil tank and remove the oil pump drive shaft. Then Plug/cap the oil lines to the fuel and oil pumps.
Questions to everyone here. If I do this, will the motor go into slow mode, if it is present on this motor? Is slow mode on this motor? I don't think so. Is there anything else I need to disconnect electronically when removing the oil injection?
