93 70hp force power and rpm loss
gsxr11
3 cylinder single carb,<br />motor was running fine turning 5k at 39mph....<br />did some tight turns at slower speed but at wot<br />boat sort of spunout like a car would do so i <br />cut power quickly. motor started running rough at<br />idle and stalled, after which it took several tries<br />to get going caulse motor would stall when put in gear. after getting it going it would only turn<br />4500rpm at wot... carb butterfly is opening all the way at wot.. any ideas as too what happened???
roscoe
Re: 93 70hp force power and rpm loss
Check the compression.<br />You may have broke a ring or otherwise damaged the motor if it over-revved during the spinout.
speedwrench
If compression OK (should be around 125# and even)<br />pull intake manifold and check reeds. Bad reed on one cylinder will cause exact symptoms you have.
gsxr11
COOL, gonna check comp. tonight then reeds if need<br />be...<br /><br />i talked to the local force dealer and he seems<br />to think its electrical....<br />i'm gonna check the mechanical things first..<br />let ya know what i find tonight...
gsxr11
ok,<br />i got motor hot did comp. test all three cyl. are<br />at 115psi even....<br />i didn't have time to check the reeds, i did a de-carb the motor runs 4800 at 37mph now.<br /><br />motor ran good from idle too wot, it still acts<br />as if the throttle isn't opening all the way...<br /> <br />so i shut motor off and fished for a hour, when i started it up again the bad idle was back but the motor still ran at 48-4900 but it wasn't crisp<br />on throttle responce like it was...
speedwrench
Pulling the intake to check reeds is minor job. They will be right there in plain sight. Should be able to use same gasket. Seal with THIN coat of RTV if need to, but DO NOT let any squeeze into the manifold. If you do and the reeds aren't bad, they soon will be.
eurolarva
after restart with bad idle try pushing the choke button in for a second. Does this smooth out the idle, kill the motor or have no effect? if it smooths out the idle you probably have a gas problem
wakebite
This may be way out In left field, But I've seen It on a few occassions. Because of your hi speed mess'in around, your fuel pick up In the tank could have picked up some trash or water. I just seemed coincidental that all this happen at one time, but seemed to Improve over time...
roscoe
If comp and spark are good, time to get into the fuel system. I would start with pulling the carb, look at the reeds, then rebuild the carb.
gsxr11
havn't had time to check it yet, i'm gonna try tonight... river is muddy right now so i can't test run yet either... but i will look at the reeds and check fuel lines..
gsxr11
ok, i pulled the reeds and they look fine..<br />no cracks and they all are laying flat...<br /><br />whats next to check ???
wakebite
Take a sample of the fuel. Diconnect fuel line at engine and pump a couple pints into a glass jar; look for water or trash....
WhiteHorse
Fuel delivery may well the problem, but I would open the fuel pump, check to see if the junk is right there first.
96force 75hp
How to check reeds? Could this be my problem with bad idle and strange tac rise and fall.
gsxr11
ok no junk in fuel or in the fuel pump,<br />diaphrams are not leaking and the check valves<br />are still in good condition.....<br />fuel filter is new...
eurolarva
Sounds like it is time to rebuild carbs. Kits are about 14 bucks per carb. Should get the fuel pump rebuild kit and do that as well. It could be electrical but the fuel system is easier to troubleshoot and repair.
vondean
Have you checked the Switch and the Coils? See if the plugs are soaked, you have no spark
pnwboat
Hey vondean.....looks like you're responding to a post that is 11 years old.
