I have a 1993 Johnson 200, modle VJ200STLETF.<br />I replaced the powerhead over the winter and now have 8 hour of break-in time on this motor. The powerhead was replaced because of a failed oil delivery issue that is now resolved. <br />Since replacement, the motor has failed to totally shut down when the switch or even the safety lanyard is pulled. The motor, when cold or hot, sputters and spits like it is dieseling, and will only die if I flood it out with the primer switch. Other than this, the motor has performed flawless at all levels.<br />The motor was timed/sink/linked by a Pro and all the tests I have run with an OHM meter have turned up negative. I have replaced the switch out of desperation, but with no change. I am ready to re-do the trouble shooting with your help please, so that I can find out what step I have obviously missed.
