Re: 92 Yamaha 8hp cuts out at full throttle
Removing the in-line filter would be the first thing to try. If it's air locked or just partially blocked, it might be allowing only enough fuel to pass for low end performance. If it runs the same with the filter out, disconnect the fuel hose from the carb, put that fuel line in a small container and pull the starter rope. If the fuel line delivers a good flow, your pump and tank hoses are OK. Look next at the carb. If the fuel delivery is not good the only things left are the fuel pump or the tank lines are sucking air. Be sure you look closely at the 'O-rings' in the tank hose ends too.
