92 XP with EXTRA MOTOR MOUNT????
JKEP44
I was cleaning inside the hull and reached under the motor looking for junk (you know the usual stuff, bud light caps, nails, washers, a G.I. Joe man head!!!) and felt a round object. Only after loosening motor mount bolts did I retrieve a motor mount. I looked and the four exterior ones were there. Is this supposed to be mounted under the motor and if so why? Thanks Kep.
Jeff Walkowiak
Re: 92 XP with EXTRA MOTOR MOUNT????
If it is a good mount save it,, YOU WILL NEED IT soon enough, there are only 4 mounts.
JKEP44
Thanks for the info Jeff.
