92 XP 200 Evinrude sputtering on take off.
Sivart
During take off it seems to load up.About half way through plane it cleans up and runs great to nearly half throttle. At full throttle it seems to "lose" a little torque but when you back off it picks back up. I have installed new spark plugs per everyones advise here a while back. <br />I purchased Seafoam deep creep yesterday, will that help with this problem? It does seem to load up quite a bit when idling and it idles a bit rough. I thought at first it was bad gas but I have since burnt 2 tanks. it does run better the harder its ran and will eventually clean up if ran WOT but I cant afford to run this thing WOT all the time.<br />Thanks in advance for any advice.
flech01
Re: 92 XP 200 Evinrude sputtering on take off.
Hello<br /><br /> If I mite throw in my two cents. Have you checked the timeing and how are those carbs. I can't tell you how many times i've read in this forum to check the carbs. Seams a little junk in the carbs can make it run bad or not at all. <br /><br />I my self have just heard about this decarbing the engine. I am planing on trying this. Please let me know how it works.<br /><br />I also read to check all those fuel lines and make sure the bulb is working good. <br /><br />Have you tried a portable tank. <br /><br />Well I hope I helped.
Sivart
I have not checked the timing yet. Of course I purchased this boat during the busy time of the year and the local service shop cant get me in for 3 weeks. I do not have a problem with most repairs but not ever working on a motor like this I would rather not make an error. I suspect the carbs need rebuilt that is why I was wondering about the Seafoam. The guy I purchased the boat from told me that it has a rebuilt power head because the oiler quit working. I beleive him because it does not have the oiler on it anymore and when I replaced the plugs the pistons were shiny as new, all of them. I have done a compression test and everything is fine there. The bulb seems to be fine. It pumps up good and does not collapse during use. As far as a portable tank no I have not tried that. I did drain replace the fuel that was in the built in tank though.
flech01
Well before I would go paying a shop to check it out I would try a portable tank and mabe try to rebuild those carbs. <br /><br /> I have a 115 hp johnson and I am by no means an expert. I have rebuilt my carbs. I had a machanic check my work and he said perfect. It was simple to do. I don't know what year or model or horse power you have but if you like to save a little money its a place to start.
flech01
I said in my last post to rebuild the carbs.<br /><br />Mabe you can just clean the carbs.
