Kenny Bush
- Mar 24, 2002
- 564
Can anyone out there tell why I am burning pistons. I have a carb'd 92' mercury 200 with extra long shaft. The motor has less than 50 total hours on it. I bought it with no compression in #1 and #2. When I tore into it, I found that the piston tops were melting away. I replaced pistons 1 and 2 and proceeded with breakin. After about 15 hours of double oil breakin, number 3 is dropping compression. Pulled head and found #3 is melting away. When I rebuilt it the 1st time, the timing was way advanced but corrected it to factory specs. Now after 15 hours #3 is coming apart. All my plugs are oily and I have not even showered down on this motor yet. Could it be ignition? The timing is on the money.
