It clicks then tries to start seadoo than clicks. the solenoid is only three months old. if I jump the solenoid and it turns the motor is the solenoid good or bad?
the solenoid may have a bad ground try running a new ground directly to the battery negative terminal if it makes a difference you need to replace the ground wire old skies usually have serious ground wire issues .
