92 dt140 repair question?
edjr
tilt and trim was leaking down and the boat had no power at wot so i took it to a certified suzuki dealer to have it fixed. he says that the tilt and trim motor/valve body are no longer availble? wants to replace it with a cmc? says he took carbs apart ( cleaned them ) should fix wot probelm. does this sound like the correct fix? if this was in your shop how long would this take?
bcopelan
Re: 92 dt140 repair question?
The tilt and trim motor/valve body are no longer available and he wants to replace it with a cmc? Will that work?
