for some reason the engine its not getting enogh fuel. well mesing around i noticed you need a good closed/sealed system in the fuel tank so the carb can make a vacuum in there and draw more fuel right? i took the carb apart and everything was pretty much nice and clean.<br /><br />i'm not familiar with 2 stroke engines but for what i can see its no science!<br /><br />also, starting it on dry land do you turn the water on then start, then shut it down water off, like an outboard? thanks all
