G'day all
I have a quick question for you all, if you disconnect one of the fuel pump to carb lines how much and how often should it pump out? I have an issue where this motor won't idle off the choke, I have searched here and all recommendations were to rebuild the carbs, which I have done, stripped and cleaned, and a kit through both, set up timing etc as per book, but it won't idle off the choke? I can get it to idle if I wind the idle mixture screws out about 4-5 turns but it it crap. Choke pulled out idles okay, pulled the carbs apart again, all good, still no idle off choke. Pulled pump to carb line and it gives a little squirt once with a good pull of the starting rope, is that enough? I am at a loss otherwise?
Cheers
Cheers
