'92 350 mag fuel pump vacuum line
Josh in Pa
I am replacing the fuel pump on a '92 350 mag. The previous owner installed an electric pump, I am putting on the correct merc. mechanical pump. Where does the vacuum line off the fuel pump go to? It has a Weber 4 barrel. Thanks for the help,
Josh
mkast
Re: '92 350 mag fuel pump vacuum line
That's not a vacuum line.
It's a fuel line to the carburetor, in case the pump diaphragm ruptures, send fuel/oil to the carburetor, should be clear, visual indication.
Mkos1980
Should be a little port behind where the fuel line goes into the carb at a little angle.
