Okay, it is time to get some extra help on my 1992 Johnson Evinrude fast strike 150 hp. My current problem is I have a loss of WOT when the prop is under a load. The motor runs great in idle. I can leave the engine running with water ears and you wouldn't know anything is wrong. I am able to idle around the lake without any issues. Once I take off to plane out, there is a hard stop at 3000 rpm and the engine sounds like it is bogging down.
I have replaced almost everything and two boat mechanics have had this. I am close to $3000 in the hole so the problem has to be something small...
Here is the history...
I was having a loss of power when pulling on the trailer and the motor was missing at high end. The first mechanic replaced my fuel pump and said that it was fixed. It wasn't, carb bowls were warped and fuel was leaking. I Rebuilt the carbs and cleaned them Replaced powerpack/ coils/plugs/ spark plug wires. Still was having an issue. Second mechanic replaced temp switches and it fixed my loss of power pulling on trailer. He put in new stator and tried a CDI, OEM and Sierra powerpack.
I have done a few things since but I still am having a loss of WOT. I have blown air through all fuel lines.
The oil pump is disconnected. I mix my own oil.
Any advice anyone can give, it is greatly appreciated.
Thanks,
Cmill
Thanks,
Cmill
