Helping a friend with his boat when I notice that when you look at the 4 carbs from the front, only 3 have brass tubes protruding from under their throats. Also the one with the missing tube is overflowing when the primer bulb is squeezed. Are these two things related and how do you remove/replace these tubes. the carbs are black plastic and I dont see any adjustment screws. Thanks Robby
