91 OMC 50hp
dsinger
91 50hp OMC has a rattle just above the cavitaion plate any ideas on what it is..
dsinger
Re: 91 OMC 50hp
Well what is in the lower end of the motor and above the cavitation plate that will clank around
Silvertip
Re: 91 OMC 50hp
Shift linkage, drive shaft bearing, water pump impeller disintigrating, loose water pump assembly, and a bunch of parts inside the lower unit that are transmitting noise up the drive shaft so it only "sounds" like that's where the noise is coming from.
