Motor will not idle until at least 2200rpm.<br />Carbs been clean 3 times thinking it is the carbs. Decarb motor and replace with new plugs(BU8H)and still will not idle. Running unit with new gas on a test gas tank. Will sometime not stay idle at 2200rpm. Can hit choke and stay on for a little bit and die out. Motor starts fine and will stay on for 10-15 second and die. Have ran motor in open water at 4500rpm and it run fine at high speed. Any help would be great.
