Hello, I am new to iboat.<br />I got a problem with my 91 merc xr4. It will not idle. I can let it sit at 2000 rpm and may stay for about 20 second and will die out. Can hit the choke and would stay alive for a little longer and still would die. I clean the carbs about three time thinking it is the carbs. De carb it with outboard decarb. Changed all the plugs with new after decarb,but still same result. Will start with no problem. Try to run it in open water and max out at 4500 rpm. Seem to run ok there. Any help would be great. Running out of ideas. Thanks
