Re: 91 merc tracker alarm
Trent,<br />you are right on the money! Thanks. I disconnected the wire and no alarm. Can you tell me where the sensor is located and if I can test the float and sensor? There is a sqaure clear plastic box that I can see soldered located bottom corner right side under cover. It appears to have a small area that could possibly be burnt (looks brown on soldered part) could this be the culprit)? <br />Thanks
