Re: 91 merc 135 carbs/floats
Mike, I have the same motor, same year on my bass boat. I rebuilt my carbs last year and it wasn't difficult at all. It was harder to find the parts than to do the work. Some yokel had put in viton tipped needles and they didn't have the retainer clips that connect them to the floats. Not suprisingly, they kept getting jammed in the seats and that's why I ended up rebuilding the carbs shortly after buying the boat.<br /><br />Anyway, my motor runs like yours and the bulb doesn't get hard either. I know the carbs are set up and working correctly so I assume it's the bulb. Cheapest to try so do that first.<br /><br />I just haven't had the time to adjust the carb mixtures and would prefer a rich motor to a lean one. Plugs are cheap.<br /><br />One thing a guy I work with mentioned is there may be some type of plastic plug in the engine behind the carbs, It's supposed to melt in the event of overheating and create a rich condition to save the motor. I didn't check this when I did the carbs and don't know if he's right or not. My motor was used and I don't know the history so if it was overheated at one point, I don't know. I bought the Seloc manual and haven't found any reference to this "plug" in there. I plan to adjust the mixtures and then dig deeper if necessary...
